Unable to generate bsp project from eclipse.
In Eclipse when I click "Finish" to create new BSP project based on my .sopcinfo file, I get error:
" Executing: wsl dos2unix create-this-bsp; ./create-this-bsp --cpu-name nios2_proc --no-make (D:\intelFPGA_lite\Projects\New_Proj\software\Proj_SW_bsp)
'wsl' is not recognized as an internal or external command,
operable program or batch file."
Then I found this:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2019/error--failed-to-execute--wsl---create-this-bsp-no-make.html
So, I tried to launch Eclipse from command shell, and it made no difference.
Is there any new fix for this ugly problem ?
Or should I use older version ? Which ?
I am using Quartus II Prime Lite 19.1
- Ahmed_H_Intel1
Maybe the WSL isn't installed correctly, can you please follow the steps in the link below?
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.html
- imarz1
Yes, WSL was not actually installed. Thank you.
Now, I am getting new error:
/bin/bash: dos2unix: command not found
./create-this-bsp: line 4: $'\r': command not found
./create-this-bsp: line 11: $'\r': command not found
./create-this-bsp: line 20: syntax error near unexpected token `$'in\r''
./create-this-bsp: line 20: ` case "$1" in
Could it be path finding issue ? Or am I missing something ? I do not even know where dos2unix is installed.
Do I need to do something in Eclipse to help it find this dos2unix ?
- imarz1
I was able to resolve the issue, and my Eclipse now compiles perfectly.
It turns out this Intel page https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.html
which has instructions on how to install WSL, was missing key instruction shown below as #a:
a. sudo apt-get update ---- this was missing from Intel instruction
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
As a result, during installation of WSL I was getting Linux error "E: Unable to locate package wsl".
Then later in Eclipse I was getting the error: /bin/bash: dos2unix: command not found , and I could not compile the project.
