Unable to generate bsp project from eclipse.
Maybe the WSL isn't installed correctly, can you please follow the steps in the link below?
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.html
Yes, WSL was not actually installed. Thank you.
Now, I am getting new error:
/bin/bash: dos2unix: command not found
./create-this-bsp: line 4: $'\r': command not found
./create-this-bsp: line 11: $'\r': command not found
./create-this-bsp: line 20: syntax error near unexpected token `$'in\r''
./create-this-bsp: line 20: ` case "$1" in
Could it be path finding issue ? Or am I missing something ? I do not even know where dos2unix is installed.
Do I need to do something in Eclipse to help it find this dos2unix ?
- imarz16 years ago
I was able to resolve the issue, and my Eclipse now compiles perfectly.
It turns out this Intel page https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.html
which has instructions on how to install WSL, was missing key instruction shown below as #a:
a. sudo apt-get update ---- this was missing from Intel instruction
b. sudo apt install wsl
c. sudo apt install dos2unix
d. sudo apt install make
As a result, during installation of WSL I was getting Linux error "E: Unable to locate package wsl".
Then later in Eclipse I was getting the error: /bin/bash: dos2unix: command not found , and I could not compile the project.
- Jesper5 years ago
What is even more confusing is that WSL and the Linux distribution that you may have installed under Windows 10, such as Ubuntu, is not the same!
I had to open WSL console in Windows 10 and install make and dos2unix. Installing it in my Ubuntu installation did not work.
This is very frustrating. There should be a much simpler way to install the necessary tools for NIOS than this.
