15 years agoUnable to connect to Quartus II Programmer JTAG Server
I'm trying to set up a JTAG Server on one PC and connect to it from another PC. I have installed Quartus II 10.1 Programmer on both PCs. On the first PC I have also installed an USB Blaster and confi...
9 years agoYes, I got it to work. It was some problem with 32-bit and 64-bit versions of the jtagserver.exe
When I installed the full Quartus II software, it worked if I started the programmer from inside Quartus II 64bit. When I only had the stand alone programmer and signaltap installed, it was impossibe to get it to work.
