Altera_ForumHonored Contributor17 years agoUART Receiver :hex 81 become 0 Hi. I have a UART receiver that manage to capture the data(led on) from hex 0 until hex80 in de2 board. However if more than hex 80 all the leds will be off. Besides, the same problem goes to th...Show More
Altera_ForumHonored Contributor17 years agothe problem have been solved automatically when i use different computer.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
