9 years agoType problem? Compiler doesn't help me!
Hi everyone,
My software works for the compilation. But now I had a table 7seg to display my work. But it doesn't compile without error! I'm lost. My two questions are: questions 1): Why this line is not working? type rang0to15 is natural range (0 to 15); --With or without () have the same error message! --Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(25) near text "natural"; expecting "(", or "access", or "array", or "file", or "range", or "record" questions 2): Why this line is not working? Q7Seg <= Table_Nbres((0 to 15)iCntBCD); --Outgoing: 7SegLED with cast of type --Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(51) near text ")"; expecting "!", or "=>" Thank you in advance for your help. Part of my soft : --4 bits BCD counter. -- VHDL Language and Board: : ? (not with me right now!) library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity LabProfBCD4BITS is port( Clk: in std_logic; nReset: in std_logic; Q: out std_logic_vector(3 downto 0);--For testing soft in simulation. Q7Seg: out std_logic_vector(7 downto 0) –New version. ); end entity LabProfBCD4BITS; architecture bhv of LabProfBCD4BITS is --CntBCD is signal iCntBCD: natural (3 downto 0);--Signal for internal computing. constant MaxDelay: natural :=50000-1; signal iCntDelay: natural range 0 to MaxDelay; signal CntUpBCD: std_logic;--to increment iCntBCD. --type rang0to15 is natural range (0 to 15); --With or without () have the same error message! --Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(25) near text "natural"; expecting "(", or "access", or "array", or "file", or "range", or "record" --type tBCD7Seg is array (rang0to15) of std_logic_vector(7 downto 0); --it doesn’t work!?! type tBCD7Seg is array (0 to 15) of std_logic_vector(7 downto 0); --With bit_vector, it looks also working. constant Table_Nbres : tBCD7Seg := ( -- Dpgfedcba "00111111", -- 0 "00000110", -- 1 "01011011", -- 2 {[And so on]} "11111001", -- D --show "E.", means Error. "11111001", -- E "11111001" -- F ); begin Q <= std_logic_vector(iCntBCD);--Used for simulation. Work well. Q7Seg <= Table_Nbres((0 to 15)iCntBCD); --Outgoing: 7SegLED with cast of type --Error (10500): VHDL syntax error at LabProfBCD4Bits.vhd(51) near text ")"; expecting "!", or "=>" --Q7Seg <= Table_Nbres(iCntBCD); --Outgoing: 7SegLED without cast of type --Error (10380): VHDL error at LabProfBCD4Bits.vhd(20): natural type is used but not declared as an array type {[The line 20 is: signal iCntBCD: natural (3 downto 0);-- In this case, the error is that no have a cast. Both type are different.]}5 Replies
1. This is a mix up between two things. You have a mix of subtype syntax and type syntax. A type will declare a brand new type, like an array type, or enumerated type. (0 to 15) would be used when declaring an array or an array type:
eg: type my_array_t is array(0 to 10) of integer; signal sig : std_logic_vector(7 downto 0); What it look like you are trying to do, is declare a subtype, as you are limiting the range of an existing type: subtype rang0to15 is natural range 0 to 15; -- no () needed 2. I dont quite know what this is - but it is not legal. And I dont know what the Table_Nbres type is. You also cannot declare a range as a type. Did you mean: Q7Seg <= Table_Nbres(0 to 15); This is also broken, because rang0to15 is not legal. You could write: type tBCD7Seg is array (rang0to15'low to rang0to15'high) of std_logic_vector(7 downto 0);, but it would be more sensible to write type tBCD7Seg is array (0 to 15) of std_logic_vector(7 downto 0); - Altera_Forum
Thank you for your answer,
--- Quote Start --- 1. This is a mix up between two things. You have a mix of subtype syntax and type syntax. subtype rang0to15 is natural range 0 to 15; -- no () needed --- Quote End --- Yes you are right. --- Quote Start --- 2. And I don't know what the Table_Nbres type is. You also cannot declare a range as a type. --- Quote End --- The type of Table_Nbres is: type tBCD7Seg is array (0 to 15) of std_logic_vector(7 downto 0); The type of Q7Seg is : (Declared in entity) Q7Seg: out std_logic_vector(7 downto 0) The type of iCntBCD is: This var contains the position in the table Table_Nbres. signal iCntBCD: natural (3 downto 0); Now; Q7Seg <= Table_Nbres((0 to 15)iCntBCD); (0 to 15) is a cast for iCntBCD IS IT RIGHT to declar the cast like this? OR WHAT IS WRONG? Thanks for your reply. - Altera_Forum
Is illegal. naturals and other integer types do not have accessible bits. Also, 3 downto 0 is illegal for an integer type. did you mean signal iCntBCD : natural range 0 to 3; --- Quote Start --- IS IT RIGHT to declar the cast like this? OR WHAT IS WRONG? --- Quote End --- You cannot do this. I still cannot quite see what you're trying to do. - Altera_Forum
--- Quote Start --- signal iCntBCD: natural (3 downto 0); Is illegal. naturals and other integer types do not have accessible bits. Also, 3 downto 0 is illegal for an integer type. did you mean signal iCntBCD : natural range 0 to 3; --- Quote End --- No, not with range. With range means, only the value 0, 1, 2 and 3 is available. AM I RIGHT? My thaught was: I want an unsigned integer counter with 4 bits. (And, in plus, init at 0) But if I write: signal iCntBCD : unsigned integer :=0;--I have a counter of 32 bits. AM I RIGHT? When I want to add 1 to iCntBCD, I have to write: iCntBCD = iCntBCD + 1 ; When I want to send iCntBCD to Q output, I have to cast iCntBCD, like this: Q <= std_logic_vector (iCntBCD);--Like I did. I hope it send to Q only the 4 LSB and ignorre the others bits without any error during compilation! If I want only 4 bits, I must write: signal iCntBCD : std_logic_vector(3 downto 0) := '0000'; -- AM I RIGHT? When I want to add 1 to iCntBCD, I have to write: iCntBCD <= (iCntBCD + '1') :--IS IT CORRECT? When I want to send iCntBCD to Q output, I have to do, without cast, like this: Q <= iCntBCD; --No cast, because both have the same type. Which methode, do you think is better? IF EVERY THING IS OK, I will modify my software and test it tomorrow, if the classroom is open. If not I will do it Monday afternoon, swiss time. I think, I'm starting to understand what's going on! thank you very much. I will send you an other message with your second answer soon. - Altera_Forum
--- Quote Start --- signal iCntBCD : unsigned integer :=0;--I have a counter of 32 bits. AM I RIGHT? --- Quote End --- No - there is no such thing as an unsigned integer type in VHDL. The integer type has no bits, and integer is always signed. I think you mean the unsigned type:
--- Quote Start --- When I want to send iCntBCD to Q output, I have to cast iCntBCD, like this: Q <= std_logic_vector (iCntBCD);--Like I did. --- Quote End --- Yes, you can do that - but why make Q a std_logic_vector? why not declare it unsigned and then no type conversion is needed. --- Quote Start --- If I want only 4 bits, I must write: signal iCntBCD : std_logic_vector(3 downto 0) := '0000'; -- AM I RIGHT? When I want to add 1 to iCntBCD, I have to write: iCntBCD <= (iCntBCD + '1') :--IS IT CORRECT? When I want to send iCntBCD to Q output, I have to do, without cast, like this: Q <= iCntBCD; --No cast, because both have the same type. --- Quote End --- You mean "0000" - ' denotes a single character, " is for strings. This code will only work with non-standard vhdl - it requires the std_logic_unsigned package - this is not a VHDL standard. Personally, I use the first method as that is what is required in most industry - using Standard VHDL. But I would leave the Q output as unsigned. the second method is non standard.signal iCntBCD : unsigned(3 downto 0) := to_unsigned(0, iCntBCD'length); --then add one: iCntBCD <= iCntBCD + 1;
