9 years agoType problem? Compiler doesn't help me!
Hi everyone, My software works for the compilation. But now I had a table 7seg to display my work. But it doesn't compile without error! I'm lost. My two questions are: questions 1): W...
9 years ago --- Quote Start --- signal iCntBCD : unsigned integer :=0;--I have a counter of 32 bits. AM I RIGHT? --- Quote End --- No - there is no such thing as an unsigned integer type in VHDL. The integer type has no bits, and integer is always signed. I think you mean the unsigned type:
signal iCntBCD : unsigned(3 downto 0) := to_unsigned(0, iCntBCD'length);
--then add one:
iCntBCD <= iCntBCD + 1;
--- Quote Start --- When I want to send iCntBCD to Q output, I have to cast iCntBCD, like this: Q <= std_logic_vector (iCntBCD);--Like I did. --- Quote End --- Yes, you can do that - but why make Q a std_logic_vector? why not declare it unsigned and then no type conversion is needed. --- Quote Start --- If I want only 4 bits, I must write: signal iCntBCD : std_logic_vector(3 downto 0) := '0000'; -- AM I RIGHT? When I want to add 1 to iCntBCD, I have to write: iCntBCD <= (iCntBCD + '1') :--IS IT CORRECT? When I want to send iCntBCD to Q output, I have to do, without cast, like this: Q <= iCntBCD; --No cast, because both have the same type. --- Quote End --- You mean "0000" - ' denotes a single character, " is for strings. This code will only work with non-standard vhdl - it requires the std_logic_unsigned package - this is not a VHDL standard. Personally, I use the first method as that is what is required in most industry - using Standard VHDL. But I would leave the Q output as unsigned. the second method is non standard.
