This is my new program. It's still error with yn and err
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_signed.ALL;
--Use ieee.numeric_std.all;
entity PhamNT is
port(x_in,kd,ki,kp :in std_logic_vector(15 downto 0):=(others => '0');
clk :in std_logic:='0';
clk_op :in std_logic:='0';
yn :out std_logic_vector (15 downto 0):=(others => '0')
end PhamNT;
ARCHITECTURE structural OF PhamNT IS
signal u,y :std_logic_vector(15 downto 0):=(others => '0'); --x(n-1),Y(n-1)
signal err :std_logic_vector(15 downto 0):=(others => '0');
signal go :std_logic:='0';
signal pl_go :std_logic:='0';
signal start : std_logic:='0';
signal mic_in : std_logic_vector(15 downto 0):=(others => '0');
signal z_out : std_logic_vector(15 downto 0):=(others => '0');
signal done : std_logic:='0';
signal u_in : std_logic_vector(15 downto 0):=(others => '0');
component simp_cpu IS
PORT(start : in std_logic;
mic_in,kd,ki,kp :in std_logic_vector(15 downto 0);
z_out :out std_logic_vector(15 downto 0);
done :out std_logic;
clk :in std_logic );
END component;
component dtdk_plant is
port(x_in :in std_logic_vector(15 downto 0);
u_in :in std_logic_vector(15 downto 0);
go :in std_logic;
clk :in std_logic;
clk_op :in std_logic;
err :out std_logic_vector(15 downto 0);
yn :out std_logic_vector(15 downto 0);
pl_go :out std_logic);
end component;
begin
U_Simp_CPU: simp_cpu port map (
start => pl_go,
mic_in => err,
kd => kd,
ki => ki,
kp => kp,
z_out => u,
done => go,
clk => clk_op
U_dtdk_plant: dtdk_plant port map(
x_in => y,--x_in,
u_in => u,
go => go,
clk => clk,
clk_op => clk_op,
err => err,
yn => yn,
pl_go => pl_go
end structural ;
this is dtdk_plant component
LIBRARY ieee;
library lpm;
use lpm.lpm_components.all;
--use ieee.numeric_std.all;
entity dtdk_plant is
port(x_in :in std_logic_vector(15 downto 0):=(others => '0');
u_in :in std_logic_vector(15 downto 0):=(others => '0');
go :in std_logic:='0';
err :buffer std_logic_vector(15 downto 0);--:=(others => '0');
yn :buffer std_logic_vector(15 downto 0);--:=(others => '0');
pl_go :out std_logic:='0'
end dtdk_plant;
ARCHITECTURE structural OF dtdk_plant IS
signal u_ant :std_logic_vector(15 downto 0):=(others => '0');
SIGNAL mula1,mulb1 :std_logic_vector(15 downto 0):=(others => '0');
SIGNAL mulr1 :std_logic_vector(31 downto 0):=(others => '0');
SIGNAL adda1,addb1,addr1 :std_logic_vector(15 downto 0):=(others => '0');
constant fi :std_logic_vector(15 downto 0) := "0110011001100110";
constant teta :std_logic_vector(15 downto 0) := "0100000000000000";
signal cnt :std_logic_vector(11 downto 0):=(others => '0');
signal aux :std_logic_vector(15 downto 0):=(others => '0');
begin
mull: lpm_mult
generic map(LPM_WIDTHA=>16,LPM_WIDTHB=>16,LPM_WIDTHS=>16,LPM_WIDTHP=>32,
LPM_REPRESENTATION=>"SIGNED",LPM_PIPELINE=>1)
port map(dataa=> mula1,datab=> mulb1,clock=> clk,result=> mulr1);
adder1: lpm_add_sub
generic map(lpm_width=>16,LPM_REPRESENTATION=>"SIGNED",lpm_pipeline=>1)
port map(dataa=>adda1,datab=>addb1,clock=> clk,result=>addr1);
GEN:block
begin
process (clk_op,go)
begin
if (clk_op'event and clk_op = '1') then
if go <= '0' then cnt <= cnt+1;
else cnt<=X"000";
end if;
if cnt=X"000" then
mula1 <= (u_ant);
mulb1 <= (teta);
elsif cnt=X"001" then
adda1 <=mulr1(30 downto 15);
elsif cnt=X"002" then
mula1 <=(yn);
mulb1 <=(fi);
elsif cnt=X"003" then
addb1 <= mulr1(30 downto 15);
elsif cnt=X"004" then
aux <= (addr1);
u_ant <= (u_in);
elsif cnt=X"005" then
adda1 <= (x_in);
addb1 <= (-aux);
elsif cnt=X"006" then
err <= (addr1);
yn <= (aux);
pl_go<='1';
elsif cnt=X"007" then
pl_go<='0';
if go='0' then cnt <= X"008";
else cnt<=X"000";
end if;
end if;
end if;
end process;
end block gen;
end structural;
