14 years ago --- Quote Start --- hi guys ..... i have a system with 2 cpu ...one running nios and another running linux..... i had some problens with 2 jtags.........and a solution ....remove 1 jtag and put a serial port :) voila! dont forget --instance=(your instance) try it Franz Wagner --- Quote End --- 2 jtags? Do you mean 2 JTAG devices (such as a JTAG debug core and a JTAG UART), or 2 JTAG UARTs? I assume using a serial port would require a hardware change?
