9 years agoTwo questions about intel FPGA opencl sdk !
I have a DE1-SOC board and attempt to build the OPENCL environment. The first question——I downloaded the 16.1 SDK and chose CENTOS 7 as the linux OS , but found SOCEDS 16.1 is not supported by ...
9 years agoThe software and OS support matrix is here:
http://dl.altera.com/requirements/16.1/ SoCEDS is not supported on CentOS 7 at all (regardless of version). You should use CentOS 6.5. Make sure to read the Getting Started guide for your board and set it up correctly.
