13 years agoIt looks like you have created an XOR gate. (Z <= CPIN XOR CPINH;) I'm not sure if this is the desired behavior.
If your initial description is correct, I agree with Tricky - use a master clock to synchronize your behavior. Something like:PROCESS(CLK, RESET)
BEGIN
IF (RESET = '1') THEN
cpin_reg_s <= '0';
cpinh_reg_s <= '0';
cpin_reg1_s <= '0';
cpinh_reg1_s <= '0';
ELSIF (rising_edge(CLK)) THEN
--register your inputs to prevent timing issues
cpin_reg_s <= CPIN;
cpinh_reg_s <= CPINH;
--remember what last register states were
cpin_reg1_s <= cpin_reg_s;
cpinh_reg1_s <= cpinh_reg_s;
--make decision to do stuff
Z <= (cpin_reg_s AND (NOT cpin_reg1_s) AND (NOT cpinh_reg_s)) OR (cpinh_reg_s AND (NOT cpinh_reg1_s) AND (NOT cpin_reg_s));
END IF;
END IF;
END PROCESS; Be sure that your clock is significantly faster than your maximum input transition rate.
