13 years agoThis is quite the ugly problem. I think more information is needed to recommend how to help.
CPIN and CPINH: Are these clocked inputs? What is the maximum toggle rate of your inputs? Do you have any actual clocks available in your design? If so, what speed(s)? If both CPIN and CPINH have the same maximum toggle rate, is the phase relationship between the two known? Side note: "Z <= X XOR Y;" does not need to be wrapped in a process. It can stand alone and will generate as you would expect.
