James_B
Contributor
5 years agoTurn On Netlist Viewers Warning with Netlist Viewers Enabled
I have a large design that is filling up 60% of a Cyclone V A9 device, and I have the option of "Run Netlist Viewers Preprocessing during compilation" turned on in the compilation process settings. ...
RichardT_altera
5 years agoHi @James_B
I don't think it is a warning message but just a tip for you to reduce the loading time.
Since you have enabled in the compilation setting, then you can safely ignore that message and you should see that the RTL viewer open faster.
Richard Tan
