trying to use axi4stream VIP with VCS. it fails due to not finding axi4stream_initialise_SystemVerilog function
NEED axi4stream_initialise_SystemVerilog definition....
see below
there is a "weak" axi4stream_initialise_SystemVerilog in vcs_hdrs.h
not same as function called in Error-[DPI-DIFNF] DPI import function not found mgc_common_axi4stream.sv, which I can't find defined anywhere,
Declaration (need Definition to match)
import "DPI-C" context function longint axi4stream_initialise_SystemVerilog
int usage_code,
string iface_version,
output longint master_end,
output longint slave_end,
output longint clock_source_end,
output longint reset_source_end,
output longint _monitor_end,
input int AXI4_ID_WIDTH,
input int AXI4_USER_WIDTH,
input int AXI4_DEST_WIDTH,
input int AXI4_DATA_WIDTH
- MuhammadAr_U_Intel
Contributor
Hi, Please refer to AXI VIP User guide in reference below and run the examples provided with the Quartus installation to get familiar with it, https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/mentor_vip_axi4_stream_ae_usr.pdf Page 189 Chapter 12 Getting Started with Qsys and the BFMs Thanks, Arslan - BDITT
I had used the aforementioned user guide.
I am trying to modify the VIP for use with our own design.
Evidently its not supported.
