WDitt1
7 years agotrying to use axi4stream VIP with VCS. it fails due to not finding axi4stream_initialise_SystemVerilog function
NEED axi4stream_initialise_SystemVerilog definition.... see below there is a "weak" axi4stream_initialise_SystemVerilog in vcs_hdrs.h not same as function called in Error-[DPI-DIFNF] DPI import fu...
BDITT
7 years agoI had used the aforementioned user guide.
I am trying to modify the VIP for use with our own design.
Evidently its not supported.
