Trying to install FIR II IP CORE
- FIR II IP CORE is included in IP Base suite.
- The IP Base Suite is also installed with the Intel Quartus Prime Lite Edition Software. Full licenses to this suite are purchased separately.
- The free Intel® FPGA IP Evaluation Mode allows you to evaluate licensed Intel® FPGA IP cores in simulation and hardware before purchase. You can use Evaluation Mode to test the IP core.
- Intel Quartus software, click Assignments ➤ Settings ➤ Compilation Process Settings.
- Click the More Settings button.
- For Intel FPGA IP Evaluation Mode, select Enable
Reference
https://www.intel.com/content/www/us/en/programmable/products/intellectual-property/design/ip-base-suite.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/megacore-ip.html
Anand
- ESUTT7 years ago
Thank you Anand! I found it.
Do you know how to generate .hex files? Or if they are automatically generated somehow?
Eric
- AnandRaj_S_Intel7 years ago
Hi Eric,
Kindly open new case, Which will help community in tracking.
Right-click on eclipse project tool and click Make Targets -> Build as shown in Figure. Select mem_init_generate and click Build to generate the HEX file.
Anand
- ESUTT7 years ago
Thank you again Anand. Sorry I am new to this fourms and FPGAs in general.
- How do I open a new case?
- Does it have to be eclipse? I have been using either Quartus lite version or Aldec.
- Also could you give me a quick explanation of what these hex files do and why anyone would need them?
Thank you!
