10 years agoTrouble running OpenCL HelloWorld example on emulated s5_ref
I'm struggling to get the Hello World example running on emulated s5_ref. I have successfully compiled the kernel with no errors, and have also compiled the host applications (using Visual Studio 2013 - I gave up trying on Visual Studio 2015 although I think it can be done with a bit more effort). When I run the host application in debug mode it fails on the following line:
platform = findPlatform("Altera"); The code runs OK, but it always returns a null pointer and the program exits with the "ERROR: Unable to find Altera OpenCL platform." message. I have tried moving the compiled aocx file into the same folder as the source code but this does not help. Any ideas?2 Replies
Anyone have any suggestions that might allow me to debug this problem?
Many thanks, Kurt - Altera_Forum
How do you run the host program?
If you compile with the -march=emulator flag the compiler will tell you how to run the host program. you need to call it with env CL_CONTEXT_EMULATOR_DEVICE_ALTERA=<board> <host program> <host program options>.
