ShaneRock
3 years agoTrouble programming 10M02 with .pof
I was wondering if someone could help me with an issue I'm having when trying to program my 10M02DCV36 FPGA. When I program the chip with the .sof file everything is fine. However, when I try and p...
ShaneRock
3 years agoThe .pof is auto generated. I also tried generating it manually using the File>Convert Programming Files, but neither method worked. The .pof file is 83KB.
ShaneRock
3 years agoSo I was able to get this to work. I'm still not sure exactly why this made it work but, I was probing the JTAG lines and when I had the probe on the TCK line it programmed just fine
