Altera_ForumHonored Contributor16 years agoTripple-Speed Ethernet in Quartus 9.1 Hi, I'm migrating with a project from Quartus 8.1 to Quartus 9.1 and have compilation errors due to Tripple-Speed Ethernet. SOPC Builder generates the NIOS II system with this component without...Show More
Altera_ForumHonored Contributor16 years agoI found the problem, old files were in the project directory.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
