Zefu
3 years agoTriple speed Ethernet and Nios V soft processor IP unlicensed
Hi, We purchased two DK-DEV-AGF014EA development boards and are trying to compile the GHRD for the board. When generating the sof file, the assembler gives the following warnings: Warning (115003):...
Zefu
3 years agoHi Kelly,
Thank you for the info, I removed the triple speed ip from the reference design and the license issue is gone. It is a workaround but I believe we don't need the triple speed ethernet IP. The issue is solved
thanks.
Zefu
