Altera_ForumHonored Contributor14 years agoTri-state fanout converted to OR gate Hi, I'm writing Verilog code for an I2C expander with bidirectional 16-bit output. If I need to read the status of the pins into a register, which means I the tr-state output pins are conn...Show More
Altera_ForumHonored Contributor14 years agoSounds like your code doesn't utilize the pins bidirectionally.
Recent DiscussionsSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusIICompile option not saved (reversed to default)Connection bit order between hierarchyquartus pro 25.3 bug?
