16 years agoTri-state buffer
I had some question regarding the warning message below: Warning: Tri-state node (s) do not directly drive top-level pin(s) è Warning: Converted the fan-out from the tri-state buffer “tribuf” to the node “comb” into an OR gate When I find the help message it state: -------------------------------------------------------------------------------- Tri-state node(s) do not directly drive top-level pin(s) CAUSE: The design contains tri-state nodes that drive non-tri-state logic, but the chip does not support internal tri-states. As a result, the Quartus II software converts all the tri-state nodes feeding internal logic to an equivalent logic. For example, in the following design, the fan-out from the node tribuf to the AND gate is converted to an OR gate. module test1 (input oe1, data1, in, output out, inout bidir); wire tribuf, tmp; assign tribuf = oe1 ? data1 : 1'bz; and(tmp, in, tribuf); assign bidir = tribuf; assign out = tmp; endmodule ACTION: Avoid this warning by either removing the non-tri-state fan-outs of the affected tri-state nodes or replacing the tri-state nodes with non-tri-state logic. -------------------------------------------------------------------------------- From the statement, it stated that it would convert the AND gate to the OR gate, however when used the Netlist-viewer->RTL-viewer for the tribuf, there is no OR gate converted. Where can I see the changes if the warning message had approached? Thanks in advance for the help Best regards ken
