11 years agoTransceiver Toolkit Pattern Generator/Checker Memory Map
Hi all, I have modified and instantiated a 10G Transceiver example into a Stratix V FPGA. I have also incorporated the JTAG Master, Pattern Generator, and Pattern Checker. The design works well ...
11 years agoThx Dave,
That is what I was looking for. BTW, Altera seems to have hidden the field for "BYPASS". It is bit 8 of offset 1 for both the generator and checker. The memory map simply says "Reserved". You can see the BYPASS function in the TTK.
