11 years agoTransceiver Toolkit Pattern Generator/Checker Memory Map
Hi all, I have modified and instantiated a 10G Transceiver example into a Stratix V FPGA. I have also incorporated the JTAG Master, Pattern Generator, and Pattern Checker. The design works well ...
11 years ago --- Quote Start --- Yes, its in an older version of the Embedded Peripherals IP Guide ... I would upload the whole PDF but the forum has a file size limit ... here's the Chapter you need. Yes, it is totally lame that Altera has deleted this chapter and not included in the handbook (which it has done with some of the other chapters it deleted from this doc). Cheers, Dave --- Quote End --- Hi Dave, Thanks for sharing this doc. I have been looking for it for some time also.
