14 years agoIf Custom Phy is not supported for Stratix IV, is there another recommended way to use the Transceiver Toolkit in current Quartus versions, either with Qsys or without? The Toolkit example readme says to modify the design in Qsys for use with our own systems but that doesn't seem to work unless the altera_components file is edited.
Thank you for clarifying the use of the Custom Phy. I don't see it in my IP list, is it under a different name?
