Altera_ForumHonored Contributor13 years agoTraffic Light Controller with DE2 board Hi, all I am doing a traffic light controller project with using DE2 board... the code I have is compiled perfectly, but when I use the DE2 board, it doesn't work properly... Some lights shoul...Show More
Altera_ForumHonored Contributor13 years agoIt probably is a logic problem Have you simulated it? where's the testbench code?
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
