10 years agoTool for VHDL/Verilog code documentation
Hi, Can someone share experience on writing documentation for FPGA design? How do you write it? I want to write documentation for FPGA project, describe which top modules are responsi...
10 years agoI cant share because they are all protected company documents.
Usually, the document contains: 1. Reasons for the project 2. The interfaces used and why 3. The overall architecture and design functionality 4. Interface descriptions, including block to block port map, CPU register map etc. 5. Test plan, including the testbenches required, the tests required, and the hardware tests required. 6. The estimated resource usage And this should all be written and reviewed before you write much/any HDL (obviously it should be updated as things change during the implementation, as they inevitably will)
