9 years agoTo measure internal delays in circuits
Hi, I want to measure the internal delay of gates using FPGA hardware and compare the propagation delays of several circuits such as ripple-carry and carry-lookahead adders. I want to measure the...
9 years ago --- Quote Start --- Hi Tricky, Thank you for your reply. I am currently trying to compare the Real time performance of different kinds of high speed adders. See how they hold up against their theoretical performance. For this I will need propagation delay through my design. It is alright if it depends on other factors. In short I need to find the time taken by the design to give my output after I give it an input. --- Quote End --- You need a TDC to measure the tiny propagation time. Fortunately, you can implement TDC function inside older altera FPGA, for example older than CycloneIV.
