9 years agoTo measure internal delays in circuits
Hi, I want to measure the internal delay of gates using FPGA hardware and compare the propagation delays of several circuits such as ripple-carry and carry-lookahead adders. I want to measure the...
9 years agoWhy do you need to know a propogation delay through a design? you realise that this delay can vary from chip to chip, build to build and with temperature, so you wont get a very reliable measurement.
If you have a synchronous design you can provide timing specs to timequest and it will check to see if your design meets those specifications.
