11 years ago
To high result, serial fir filter VHDL
Hey, I'm beginner at VHDL and I have a problem with my serial fir filter with LUT:
LUT table: not all
library ieee;
 use ieee.std_logic_1164.all;
 use ieee.std_logic_arith.all;
 entity lut_table is
 port(
       x0,x1,x2,x3,x4,x5,x6,x7,x8  : in std_logic;
       table_out : out std_logic_vector(13 downto 0)
end lut_table;
architecture arch of lut_table is
 signal table_in : std_logic_vector( 8 downto 0);
 begin
 table_in <= x8 & x7 & x6 & x5 & x4 & x3 & x2 & x1 & x0;
 with table_in select
        table_out <= "00000000000000" when "000000000",
                            "00000001101110" when "000000001",
                            "11111110111011" when "000000010",
                            "00000000101001" when "000000011",
                            "11111011000000" when "000000100",
                            "11111100101110" when "000000101",
                            "11111001111011" when "000000110",
                            "11111011101001" when "000000111",
                            "00010001000101" when "000001000",
                            "00010010110011" when "000001001",
                            "00010000000000" when "000001010",
                            "00010001101110" when "000001011",
                            etc.
end arch.
Main unit:
library ieee;
 use ieee.numeric_std.all;
 use ieee.math_real.all;
 entity filtr_fir_da is
port (
clk, rst      : in std_logic;
 data_in     : in std_logic_vector(7 downto 0);
 data_out   : out std_logic_vector(27 downto 0)
end filtr_fir_da;
architecture arch of filtr_fir_da is
signal acc_reg, acc_next                                : signed(27 downto 0);
 signal data_out_reg,data_out_next                 : signed(27 downto 0);
signal tableout                                              : std_logic_vector(13 downto 0);
 signal adress_reg, adress_next                      : unsigned (3 downto 0);
 signal d0_reg,d1_reg,d2_reg,d3_reg,d4_reg,d5_reg,d6_reg,d7_reg,d8_reg            : std_logic;
signal d0_next,d1_next,d2_next,d3_next,d4_next,d5_next,d6_next,d7_next,d8_next : std_logic;
type x_table is array (0 to 8) of std_logic_vector(7 downto 0);
signal datat_reg,datat_next        : x_table;
 type STYPE is (load,count,result);
 signal state_reg, state_next : STYPE;
 component lut_table port(
 end component;
 begin
lut: lut_table port map(
         x0 => d0_reg,x1 => d1_reg,x2 => d2_reg,x3 => d3_reg,x4 => d4_reg,x5 => d5_reg,x6 => d6_reg,x7 => d7_reg,x8 => d8_reg,
         table_out => tableout
process(rst,clk)
 begin
       if rst = '1' then
          state_reg <= load;
      elsif rising_edge(clk) then
         state_reg <= state_next;
end if; end process;
 process(rst, clk)
begin
        if rst = '1' then
          adress_reg <= "0000";
          data_out_reg <= (others => '0');
          acc_reg <= (others => '0');
          datat_reg <= (others => (others => '0'));
          d0_reg <= '0'; d1_reg <= '0'; d2_reg <= '0'; d3_reg <= '0'; d4_reg <= '0'; d5_reg <= '0'; d6_reg <= '0'; d7_reg <= '0'; d8_reg <= '0';
         adress_reg <= adress_next;
        acc_reg <= acc_next;
        data_out_reg <= data_out_next;
        datat_reg <= datat_next;
        d0_reg <= d0_next;d1_reg <= d1_next;d2_reg <= d2_next;d3_reg <= d3_next;d4_reg <= d4_next;d5_reg <= d5_next;d6_reg <= d6_next;d7_reg <= d7_next;d8_reg <=d8_next;
   end if;
 end process;
 process(state_reg,adress_reg,data_out_reg,d0_reg,d1_reg,d2_reg,d3_reg,d4_reg,d5_reg,d6_reg,d7_reg,d8_reg,acc_reg,datat_reg,datat_next,tableout,data_in)
  begin
      state_next <= state_reg;
      adress_next <= adress_reg;
      acc_next <= acc_reg;
      data_out_next <= data_out_reg;
      datat_next <= datat_reg;
      d0_next <= d0_reg;d1_next <= d1_reg;d2_next <= d2_reg;d3_next <= d3_reg;d4_next <= d4_reg;d5_next <= d5_reg;d6_next <= d6_reg;d7_next <= d7_reg;d8_next <= d8_reg;
case state_reg is
        when load =>
                datat_next(8) <= datat_reg(7);
                datat_next(7) <= datat_reg(6);
                datat_next(6) <= datat_reg(5);
                datat_next(5) <= datat_reg(4);
                datat_next(4) <= datat_reg(3);
                datat_next(3) <= datat_reg(2);
                datat_next(2) <= datat_reg(1);
                datat_next(1) <= datat_reg(0);
                datat_next(0) <= data_in;
                state_next <= count;
      when count =>
               if adress_reg < "0111" then
                  d0_next <= datat_reg(0)(to_integer(adress_reg));
                  d1_next <= datat_reg(1)(to_integer(adress_reg));
                  d2_next <= datat_reg(2)(to_integer(adress_reg));
                  d3_next <= datat_reg(3)(to_integer(adress_reg));
                  d4_next <= datat_reg(4)(to_integer(adress_reg));
                  d5_next <= datat_reg(5)(to_integer(adress_reg));
                  d6_next <= datat_reg(6)(to_integer(adress_reg));
                  d7_next <= datat_reg(7)(to_integer(adress_reg));
                  d8_next <= datat_reg(8)(to_integer(adress_reg));
                  acc_next <= (shift_left(signed(tableout),to_integer(adress_reg))) + acc_reg;
                  adress_next <= adress_reg + "0001";
             elsif adress_reg = "0111" then
                 acc_next <=  -(shift_left(signed(tableout),to_integer(adress_reg))) + acc_reg;
                 adress_next <= "0000";
                 state_next <= result;
            end if;
        when result =>
               data_out_next <= acc_reg;
               state_next <= load;
              acc_next <= (others => '0');
       when others =>
           state_next <= load;
  end case;
 end process;
            data_out    <= std_logic_vector(data_out_reg);
  end arch;
My scale coefficients are
[ 110,-69,-320,1093,2470,1093,-320,-69,110]
For example when input signal is
[1,0,0,0,0,0,0,0,0]
my system multiple the reuslt twice so the result is
[ 220,-138, -640, 2186, 4940, 2186, -640, -138, 220]
instead
[110, -69, -320, 1093, 2470, 1093, -320, -69, 110].
Anyone help ? I think there is something wrong with last cycle of count state, because the result is delayed 10 cycles of clock, so all system count the result badly but I don't know how I can repair it ;/
1 Reply
