15 years ago
Timing with a NIOS II Multi-Cycle/Internal Register File Custom Instruction
Your opinion on the following matter would be appreciated.
I've implemented a NIOS II Multi-Cycle/Internal Register File Custom Instruction (attached here). All works well, except the design does not pass TimeQuest without timing exceptions. Let's say that my clock is with a period of 10 ns. TimeQuest reports a data violation of 15 ns from the custom instruction input to the custom instruction result/internal accumulator. This shouldn't be the case because the instruction is multi-cycle. So, I have the following question:
1. Shouldn't the SOPC builder automagically relax this in its .sdc file?
2. I'm relaxing manually the constraints and I have figured out three ways to do that.
2.1. Declare false pahts: I don't like that because these are not false paths;
2.2. Increase the max delay: doesn't sound credible either;
2.3. Introduce multi-cycle delays in the following manner:
--- Quote Start ---
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|D_iw*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src1*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src2*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|D_iw*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src1*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src2*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -setup -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|D_iw*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -hold -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src1*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -hold -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src2*}] -to [get_keepers {*cpu_0:the_cpu_0|W_alu_result*}] -hold -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|D_iw*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -hold -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src1*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -hold -end 2
set_multicycle_path -from [get_keepers {*cpu_0:the_cpu_0|E_src2*}] -to [get_keepers {*sum_prod_pulse:cpu_0_sum_prod_pulse_inst|acc*}] -hold -end 2
--- Quote End ---
The above does the job but I'm not sure if this is the right way: all the documentation I've read is that set_multicycle_path is for when you have multiple clocks with different period, and this is clearly not the case.
