9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years agoRyan, first thank you for explanation.
Nevertheless, I remains a little bit confused. Primary question - "What to start with ?" timequest generates multitude of different reports ... What report to start with ? I passed trough all selected those with timing violations. Here below the short resume of timing violations output by TimeQuest: https://www.alteraforum.com/forum/attachment.php?attachmentid=13619 There are 3 "sections", where I've found timing violations:- Summary (Setup), where violations are related to the clock ...divclk. Time report "To clock" followed divclk and revealed 10 violations
- Summary (Hold), where violations are related to the clock clk_ext_sdram. Time report "To clock" followed clk_ext_sdram and also revealed 10 violations
- Report failing path - revealed 200 violations, realted to ...divclk for both launch and latch clocks and nodes are internal, i.e. no external ports
