9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years ago --- Quote Start --- Do you mean my 2nd message on this thread ? The design was modified since that moment ... e.g. 2 PLL outputs became in phase. --- Quote End --- I meant this last post from you: Report Timing HOLD "to clock" clk_ext_sdram It could be the clk_ext_sdram is latching e.g. m_dq to sdram_dq internally then sending it to sdram. But I thought you have defined clk_ext_sdram as generated output clock.
