9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years ago --- Quote Start --- But you are latching it on divclk: is it also 150MHz and then why have you changed its phase. Although this clock of clk_ext_sdram is opposte data input but that is a trivial issue for now... --- Quote End --- Yes, data that comes into FPGA (SDRAM controller IP to be precise) is latched by u0|pll|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk (which is PLL-derived clock with 0 phase shift). And the data launch clock is PLL-derived clock with -3.5ns phase shift, so the launch clock is about half-period "advanced" with respect to latch clock and respectively the latch clocks is half-period delayed with respect to launch clock. Correct ? Probably this half-period shift is intended to account for board propagation delay ? Anyway, if I properly understood, you propose to remove phase shift in launch clock. Correct ?
