9 years agoTiming Violations workaround strategy
Hello, Probably I didn't properly define timing constraints ... TimeQuest reported quite a lot of timing violations. In this connection I have one question - does exist some straightforward a...
9 years ago --- Quote Start --- You mean why external sdram memory chip isn't clocked with the same clock as internal sdram controller ? This clocking schema I've picked from a reference design that was in support board package. By the way there was no any constraints on SDRAM interface I/O in the .sdc file. --- Quote End --- You are sending a clock to sdram chip as you have done (isn't it the clk_ext_sdram as named in your sdc). That is ok I am referring to your sdc constrains of set_input_delay/set_output_delay for sdram_dq. You are telling Timequest that sdram_dq data is clocked out from sdram chip on clk_ext_sdram. That is ok But you are latching it on divclk: is it also 150MHz and then why have you changed its phase. Although this clock of clk_ext_sdram is opposte data input but that is a trivial issue for now...
