9 years ago
Timing violations on internal nodes - how to fix them ?
TimeQuest Analyzer reported 63 "Setup" violations, and all of them are located on internal nodes.
Does exist some strategy to fix internal nodes timing violations, e.g. add some constraints in .sdc file ?
    What do you mean by "internal nodes"? Internal to what?
    Setup violations usually occur because there is too much logic between registers. The easiest fix is to add extra pipeline stages on these paths in your HDL.
    --- Quote Start ---
    --- Quote End ---
    Thanks Tricky,
    I mean "internal-to-internal".
    Here is "Top Failing Paths":
    https://www.alteraforum.com/forum/attachment.php?attachmentid=14179
    These paths come from from sdram controller IP.
    add extra pipeline stages ... you mean edit IP code ?
    If its in an IP, then no, you generally cannot edit it.
    Are you sure the constraints are correct and not too fast?
    How full is the device?
    Have you tried a different fitter seed?
    Correct or not, I'm not sure ... at least there is no ignored constraints.
    Concerning input/output delay, they were generated by the project builder - utility, delivered by board manufacturer - Terasic.
    BTW, here is the content of constraint file:
    #  This .sdc file is created by Terasic Tool.
    #  Users are recommended to modify this file to match users logic.
    #  Create Clock
    create_clock -period 20.0 -name clk CLOCK_50
    #  for enhancing USB BlasterII to be reliable, 25MHz
    create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
    derive_pll_clocks
    derive_clock_uncertainty
    set_input_delay -clock altera_reserved_tck -clock_fall 3
    set_output_delay -clock altera_reserved_tck 3
    #  Create Generated Clock
    create_generated_clock -name clk_sdram_ext -source .gpll~FRACTIONAL_PLL|fbclk}]
    create_generated_clock -name clk_data -source .gpll~PLL_OUTPUT_COUNTER|divclk}] |clk}]
    #  Set Input Delay
    #  Board Delay (Data) + Propagation Delay - Board Delay (Clock)
    set_input_delay -clock clk_sdram_ext -max -0.048
    set_input_delay -clock clk_sdram_ext -min -0.057
    #  Set Output Delay
    #  max : Board Delay (Data) - Board Delay (Clock) + tsu (External Device)
    #  min : Board Delay (Data) - Board Delay (Clock) - th (External Device)
    set_output_delay -clock clk_data -max 1.452
    set_output_delay -clock clk_data -min -0.857
    set_output_delay -clock clk_data -max 1.531
    set_output_delay -clock clk_data -min -0.805
    set_output_delay -clock clk_data -max 1.533
    set_output_delay -clock clk_data -max 1.510
    set_output_delay -clock clk_data -min -0.800
    set_output_delay -clock clk_data -max 1.520
    set_output_delay -clock clk_data -min -0.780
    set_output_delay -clock clk_data -max 1.5000
    set_output_delay -clock clk_data -max 1.545
    set_output_delay -clock clk_data -min -0.755
    set_output_delay -clock clk_data -max 1.496
    set_output_delay -clock clk_data -min -0.804
    set_output_delay -clock clk_data -max 1.508
    set_output_delay -clock clk_data -min -0.792
    #  Set Clock Groups
    #  Set False Path
    set_false_path -from
    set_false_path -from * -to
    clk_data - output of the "zero delay buffer" PLL, clk_sdram_ext - zdbfbclk output of the same PLL that is applied to the external SDRAM clock input.
    I'm not sure that such connection solution is perfect - I picked it from old Altera presentation (at least as I understood it)
    https://www.alteraforum.com/forum/attachment.php?attachmentid=14180
