15 years ago
Timing violation
Hello
I has create a symbol with the toplevel from the 5 megapixel demo project TRDB_D5M_CD_v1.0 for DE2 Board.
But when I insert the symbol in a block diagram and sets the Input/Output, after the synthese I have timing violation and the VGA-Monitor d'ont display a perfect image.
The same problem I have with the video demo on the Terasic CD DE2_TV.
In the attachment you find the two demo project, could you try on your system? Maybe your found the problem....
For any tips I thanks....
    --- Quote Start ---
    Hello
    --- Quote End ---
    in which of the projects I should find your BDF-file ?
    Kind regards
    GPK
    If you can do a "report_timing" in TimeQuest on the worst case failing path, we can help troubleshoot more directly. WHen you get the spreadsheet report, just go to File -> Export and export a .csv or .xls.
    First check that the source and destination clocks are synchronous and phase aligned.
    Mike
    can you make the bdf file yourself, --> open toplevel verilog code and then File\Create_Update\Create Symbol for Files from current Files. Then open New\Block Diagram Insert Symbol\right button mouse on Symbol and Create Inputs with right Assignment. And then RUN Synthese.
    Sorry, I don't can upload the entire project, size to big....
    I hope you find 10 minutes for this...
    Thanks you very much...
    I have resolved the problem.
    I export the Pin Assignment from the original DE2_TV inclusive the "Export back-annotated routing" and "Save a node-level netlist of the entire design into a persistant source file"
    yeppaaaa.. it works well now. I have also make a SopC Symbol and include it now I can make my camera tracking...
    Thanks a lot...
    Hey, Antonio,
    So, what happened here? Possibly you were getting Fitter assigned pin placements. That's why back-annotation would fix it. Something else?
    Mike
    yes... :confused:
    or can you specify your question?
    sorry I don't understand what you mean...
