MRenn
7 years agoTiming violation with Altera GPIO in DDR mode
I have a setup violation at the register after the input register. The input register is constrained as described in AN433. set_input_delay -add_delay -clock virt_adc_clk -min -0.6 [get...
MRenn
7 years agoHi,
I tried Phy Lite but had problems with setting the correct frequencies as I wrote 19 days before.
The text was:
In the handbook Intel recommends to use PHYLite for source synchronous Interfaces with more than 200 Mbps.
I set the Interface clock to 262.144MHz, clock rate of user logic: Full
If I do so, I cannot set the PLL reference clock to 262.144MHz. Just half of it, but I need to set this clock, because it is coming from the ADC.
I don't know why it is not possible. In the PHYLite User Guide
https://www.intel.com/content/www/us/en/programmable/documentation/bhc1410942178562.html#bhc1410941851660/en-us Table 3
the Max Core Clock Rate (Full) with Arria 10 Speed Grade -2 is 266MHz.
