18 years agoThe code has some do not do's.
The reset should be an input, not an internal signal. Having the reset as an input is the only way you can initalize your outputs and signals to a known value. There are combinational loops in the second process. The reset signal is only defined in the case where state is s0. Also, when state is s7, only cycle is defined. This will cause combinational loops. Try rewriting the code using one synchronous process. example: process (reset, clk) begin if reset = '1' then cycle <= ; --put the reset value for cycle here state <= s0; outval <= ; --put the reset value for outval here elsif clk'event and clk = '1' then case state is when s0 => state <= s1; cycle <= ; --insert cycle value outval <= ; --insert outval value when s1 => ......and so on
