13 years ago
timing requirement not met
Hello
I'm kind of new in the world of FPGA and puzzled with a timing warning message sent by quartus.
This fonction extract ratio info of an arbitrary PWM signal every period and send the ratio over a 14 bits bus to another function.
the code is as follow :
entity formfactor is
    Port (    PWM    : in STD_LOGIC;
                rst   : in STD_LOGIC;
                clk    : in STD_LOGIC;
                FF2    : out integer range 0 to 10020 );
end formfactor;
architecture behaviour of formfactor is
signal  buf_ton1, buf_ton2,buf_T1, buf_T2, compteur1, compteur2: integer range 0 to 12000;
type etats is (s0,s1,s2,s3);  --type of state machine.
signal s: etats;
signal flag: std_logic_vector (1 downto 0);
type atats is (a0,a1,a2,a3);
signal a : atats;
begin
DUREE:process (clk, rst)
    begin
    if rst = '0' then
    compteur1 <= 0;
    compteur2 <= 0;
    flag <= "00";
    elsif (clk'EVENT and clk ='1') then
       case s is
when s0 =>
compteur2 <= compteur2 + 1;
if (PWM ='1' AND compteur2 > (buf_ton2 + 10) ) then buf_T2 <= compteur2;
    s <= s1;
        flag <= "10";
else s <= s0;
end if;
when s1 =>
compteur1 <= compteur1 + 1;
if(PWM = '0' AND compteur1 > 10 ) then buf_ton1 <= compteur1;
    compteur2 <= 0;
    s <= s2 ;
else s <= s1;
end if;
when s2 =>
if (PWM ='1' AND compteur1 > (buf_ton1 + 10)) then buf_T1 <= compteur1;
                                                        s <= s3;
                                                        flag <= "01";
else s <= s2;
end if;
when s3 =>
if (PWM ='0' AND compteur2 > 10 ) then     buf_ton2 <= compteur2;
    compteur1 <= 0;
    s <= s0;
else s <= s3;
end if;
end case;
end if;
end process DUREE;
DIVIDE: process (clk)
BEGIN
    case a is
    when a0 =>
    if(flag = "10") then a <= a1;
    else a <= a0;
    end if;
    when a1 =>
    FF2 <= 100000000 /((buf_T1 * 10000) / buf_ton1);
    a <= a2;
    when a2 =>
    if(flag = "01") then a <= a3;
    else a <= a2;
    end if;
    when a3 =>
    FF2 <= 100000000 /((buf_T2 * 10000) / buf_ton2);
    a <= a0;
    end case;
    end if;
end process DIVIDE;
end behaviour;
Clock is 100Mhz
Timequest gives me a negative slack of -127 in the worst case between bufTx / buf_tonx and FF2
ex : -127.307 formfactor:inst10|buf_T2[0] formfactor:inst10|FF2[0] inst1|altpll_component|auto_generated|pll1|clk[0]
The problem is obviously in my process DIVIDE but I can not manage to find it.
Can someone give me a hint ? It would be much appreciated.
        when a3 =>
        a <= a0;
    It is ultimately saying that the logic can not run at the speed you would like it to. The line above starting with "FF2" is a bit much to expect to run at 100MHz. You will probably want to pipeline your math to make this a bit easier on the compiler to have your design meet timing.
    I might suggest keeping your * and / operations isolated by registers.
    The division operation is *VERY* slow and complex to implement in actual logic.
    The usual solution is to avoid it.
    A common strategy is to have a table of reciprocals and replace division by multiplication by the reciprocal.
    at least simplify the massive term 100000000 /((buf_T1 * 10000) / buf_ton1) to:
    10000 *buf_ton1 / buf_T1 and remember not to call them twice but once otherwise the tool creates two instants of * & / as it may not be that kind.
    Incidentally, your figures helped me find out that:
    10000 = 8192+1024+512+256+16
    hence you can shift add if you wish to trade 1 mult for adders.
