15 years ago --- Quote Start --- The receive clock comes along with the received data over the loom, so the length of the loom has no influence and you can apply the 'source-synchronous' constraint rules for SDR data with a centre aligned clock. Assuming that all signal lengths are reasonably equal we can forget about them. Else you have to add the largest positive difference in travel-time compared to the clock to the TcoMax and likewise add the largest negative difference in travel-time relative to the clock from the Tcomin (effectively making it smaller) I opened up the DS90C124 datasheet on National's web-site. On page 11 and pages 4 and 5, you can see that you get a minimal of 40% of Tcyc as both hold and setup times. You can either translate this in skew or in TcoMax and Tcomin values. Translating it in to Tco: Tcomin is 40% of Tcyc ( = Troh) and TcoMax is then 60% of Tcyc ( = Tcyc - Tros)
# set frequency in MHz
set FreqRClk 25.0# calculate cycle time in ns
set Tcyc # and create the clock
create_clock -name RClk -period $Tcyc RClk # calculate the min and max delay
set Tcomin
set TcoMax # and apply
set_input_delay -clock RClk -max $TcoMax RxD
set_input_delay -clock RClk -min $Tcomin RxD
--- Quote End --- Hi josyb, Thanks for all of your help. I am trying to make sure I understand how to calculate these things for future reference. Using the system centric approach, the required information would normally be - Max and min data path delays
- Max and min clock path delays
- External device tCO (tCO_ext)
- External device tCOmin (tCOmin_ext)
