10 years agoTiming Optimized VHDL Code
I'm looking for coding guidelines, rules, online resources, examples, etc. on how to write VHDL code that helps me achieve a higher fmax for my FPGA design. Does anybody have any good recommend...
10 years agoThis comes down to fundamental understanding - you're going to have to find textbooks on basic digital logic hardware and read a good VHDL tutorial that shows you the templates for basic elements and shows you designs - I think this often gets good reviews:
https://www.amazon.co.uk/designers-guide-vhdl-systems-silicon/dp/0120887851/ref=pd_sim_14_3?ie=utf8&dpid=41hoxajjmtl&dpsrc=sims&prest=_ac_ul160_sr116%2c160_&refrid=dh37pjhmb0pwzwt3xz68 But there are many many out there. --- Quote Start --- At this point I never thought past RTL code, besides maybe that a clocked process is something like a flip flop. --- Quote End --- In a clocked process, every bit of every signal assigned in the becomes a single flip flop. The if/elseif/else statements make the combinatorial logic. So the more layered ifs, the longer the logic chain. (this is a very crude analogy, but you will need to understand what logic your code is generating. So see the generated output - you need the RTL and map viewers, available in Quartus via Tools->Netlist Viewers.
