Altera_ForumHonored Contributor14 years agoTiming Not Being Constrained? My problem is that my design passes timing closure no matter how I constrain it (well almost). In particular, if I constrain the output timing like this; create_clock -name {real_clock} -perio...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
