14 years ago --- Quote Start --- OK, I tried to post as little as possible since I didn't want it to get too complicated. The clock grouping goes; set_clock_groups -asynchronous -group {real_clock} set_clock_groups -asynchronous -group {real_clocka} set_clock_groups -asynchronous -group {real_clockb} There's no reference to the virtual clock in my grouping. What you're saying is perhaps that's the problem? --- Quote End --- Yes, that is the problem. The first command sets all paths between real_clock and all other clocks as a false path. The second and third to the same for real_clocka and real_clockb. You probably need something like this set_clock_groups -asynchronous -group {real_clock virtual_clock} -group {real_clocka} -groups {real_clockb}
