cblixt1
1 month agoTiming models don't match measured delays
I am working with an Agilex 7 I-series device in Quartus Prime Pro 25.3. The device is fully supported by that QPP version and has final timing models. Since I am working with precise timing, I nee...
cblixt1
1 month agoFor all practical purposes, this is my design:
module ghrd_agilex_top (
input wire fpga_clk_100,
output wire master_tod_top_0_pulse_per_second,
output wire master_tod_top_0_pulse_per_second_raw
(* dont_merge *) reg sta_test1;
(* dont_merge *) reg sta_test2;
always @(posedge fpga_clk_100 or negedge system_reset_n) begin
if (~system_reset_n) begin
sta_test1 <= 1'b0;
sta_test2 <= 1'b0;
end
else begin
sta_test1 <= ~sta_test1;
sta_test2 <= ~sta_test2;
end
end
assign master_tod_top_0_pulse_per_second = sta_test1;
assign master_tod_top_0_pulse_per_second_raw = sta_test2;
endmoduleOf course the design actually contains a lot more, but it does not affect the issue at hand, which is that the STA for this part does not seem to match the measured results.
