JPrig
7 years agoTiming constraints when the clock is recovered from data
Hi, I have a serial data stream which arrives at a CPLD pin. This data stream feeds a clock recovery entity which contains a PLL with dynamic phase reconfiguration. The output of the clock recovery ...
KhaiChein_Y_Intel
7 years agoHi,
If you set false_path assignment to the clock, you will not see the violation in the timing report. If you set false path to the virtual clock and the high frequency sampling clock, the path will not be analyzed and we cannot make sure that the data is sampled correctly.
