11 years agoTiming constraints for SoC HPS SPIM routed through FPGA fabric
I'm working with a prototype project using an Altera Cyclone V SoC Development kit. We have chosen to route IO pins from one of the HPS SPIMs into the FPGA so that we can put the IOs on the HSMC conn...
11 years agoI will try set min/max delay from input pins to output pins. not sure if it is going to be accepted but set max/min input/output delay is likely to be rejected as it is meant for reg to reg path. Just a thought.
