YOGon's avatar
YOGon
4 years ago
Timing analysis for a different device without recompiling
I have a desing compiled for an EP3C5 but I need to deploy it on an EP3C10 without recompiling it. (The package is the same for both devices).
Is there a way in Quartus to analyze the timing behaviour in the EP3C10 without recompiling the design for this device?
  • sstrell's avatar
    sstrell
    The package may be the same, but the internals are different. You would need to recompile.
    You can simplify this in a few ways: add a new revision of your Quartus project with the different device set as the target or enable the second device as a migration device.
  • SyafieqS's avatar
    SyafieqS
    Yolanda,
    Yes true, it is the same package, but you still need to recompile in order to get clean timing (assuming timing is closed)
  • SyafieqS's avatar
    SyafieqS
    Yolanda,
    May I know if there is any update?
  • YOGon's avatar
    YOGon
    Your answer is clear: I have to recompile. Thank you.
