11 years agoI sent an email to a very similar question yesterday, so cutting and pasting from there(in there case they were pretty sure the problem was an inferred latch, but the steps are similar no matter what it's driving).
I usually do a “create_clock -name missing_clk -period 10.0 {name_of_unconstrained_clock_signal_in_report}”. Then update the timing netlist and do a “report_timing -detail full_path -to_clock missing_clk -panel_name missing_clk”. Then look at the Data Required Path and you should see it start at the clock you just constrained and proceeding to the latch. You might be able to get away with running derive_clocks -period 10.0 instead of manually doing the create_clock. And just type the word latch in the search box for synthesis messages, as that’s what it is in 95% of these cases. ---------- Once you find the issue, the question is if it's correct. Ideally you don't want some internal node being used as a clock and you code it so it uses the main clock instead. That's the best fix and you don't have to worry about how to time it.
