14 years ago --- Quote Start --- I have identified the precise place where timings are not being met: I have a barrel shifter that is purely combinatory between two registers. It's quite big with about 70 plus bits in size. Both registers receive the same clock. The clock has made timings according to the analyzer. The question is: Why is the analyzer not properly calculating the delays of this barrel shifter? --- Quote End --- Hi, dit they use the same clock enable signals ? Can you try to check the timing of the paths directly in Timequest ? Kind regards GPK
