14 years ago --- Quote Start --- I actually observe the problem outside the chip. I have a DAC and I observe the problem on the waveform itself. Only then did I go and use the signal tap to try to isolate the problem. The distortions I get in the captured signals with signal tap are pretty much aligned with what I observe outside the chip. --- Quote End --- Hi, which timing checks did you run with Timequest ? Kind regards GPK
